Of course it goes without saying that regular backups are happening... Preferably to an off-site location.
This computer doesn't have internet access. Long ago we decided it wasn't needed. And for the sake of security a separate computer would be used for general web use should the owner want to check up on sport team scores, etc.
I like the read of the X25-V by Intel. Sure, it doesn't seem to have the speed of the latest OCZ products Anand wrote about but it has a longer and perhaps more proven track record, the size is adequate and the price is less than others.
I think I'll order one this next week.
On another point, Jan. 12, 2009 I ordered and installed an OCZ Solid Series 30GB SSD for a very light weight PC used as a clock-in station for my nephew's childcare center.
I believe it's running Windows XP with just enough files installed (the software vendor calls it 'workstation' software) to run some clock-in software. It works by executing a program on another "server" pc which has a shared folder. Pretty simple low-end stuff but it works.
My point is, from the get-go my nephew said it seems to run slow. Well, quite honestly I never did any special alignment which I still don't know how to do. As for life expectancy of this drive, you would probably agree that there are next to zero writes involved.
Would this be the ideal use of that old Solid Series SSD?
Next point, the SSD I'm shopping for now would be on the "server" side of this arrangement and is used for all other office needs.
