SSD BSOD Problems, please help!
vlawfactor
Season's greetings.
I'm having issues with my SSD that I just got today, I'll detail everything that I think is relevant.
GA-990FXA-UD3
OCZ Vertex 256GB
And I have a 2TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD that's not anything special, I don't know if it has a name.
So I've had this computer for about a month now, minus the SSD. Windows 8 Pro on my HDD, and error-free for the most part. My SSD arrived today, and I decide to install it with my HDD still connected.
Boots up perfectly, but my SSD isn't recognized until I go into my Hard Disk Management, and create a New Simple Volume. After I did that, my SSD works fine alongside my HDD.
The plot twist is coming
I wanted my OS to be on my SSD. So, I remove my HDD, and boot up only from my SSD and a Windows 8 Pro disc. I install Windows 8 Pro onto my SSD with no errors, everything is gravy. So now I'm thinking, "yay! I'll just hook my HDD back up and the world will, all at once, collectively high five me!" I hook my HDD back up, boot up... when I notice that Windows booted from my HDD, not my SSD. Furthermore, according to My Computer, my SSD is empty -- there's nothing on it. I immediately shut down my computer, take out my HDD, and try booting up with just my SSD. I get the BSOD cache_manager error. I remove my SSD, hook up my HDD, and get the exact same error. On both drives Windows tries to auto repair and it just fails. It's an endless loop. I still have my Windows 8 install disc in my computer, but for some reason I cannot boot from it, no matter my setup in my BIOS. I'm very certain it's not a CD/DVD drive malfunction, part of me feels like maybe it's something in my BIOS (which I've barely touched).
So what seems to be the issue?
Last thing -- I have no clue how this happened, but during the endless loop of BSOD's with just my HDD attached, Windows eventually gave me the option to System Restore, which I did, and it worked. I can now log onto my computer with just my HDD attached. However, with just my SSD attached I cannot boot up, and the endless loop continues... endlessly. I still can't figure out why I can't just boot from my CD-DVD drive, and reinstall Windows 8 on it... nor do I know why I keep getting this error in the first place. Could it be BIOS related?
Basically I'm just lost. Any help or input would be greatly appreciated, and if I need to elaborate or post more information I'll do so, gladly.
Thanks to anyone who tries to help.
I'll give it a go ....
Reinstall win 8 on the SSD (with only this drive conected) and bios set to AHCI or RAID.
Get all updates and drivers loaded. Then run WEI and reboot. Then shutdown.
Now reconect your HHD, boot to bios and set boot device to your SSD as 1st. (I disable all other options here, but thats my preferance)
Now reboot and see what happens.
You still have the master boot record on the hdd. It's causing the hang-up. Do what kbp outlines and make sure your ssd is the 1st boot drive in your bios and as he says disable all others (for now). Then pluck all your data off the hdd onto an external hdd or separate partition. Wipe the OS hdd/partition and you'll be all set and solid.
Welcome to the new world of ssd! Your first time should never be easy.
