Post the rest of your system details, drivers used so we can put this in context
Those numbers do seem low to me, I also have the same drive.
Was the drive clean before you installed? (ie new or secure erased)
Try running the Perforance Optimization within SSD Magician. This will force execute TRIM and GC which may help.
Also double check your partition alignment.
Chipset and RST driver numbers would also help.
chipset @ 9.2.0.1021 ; RST @ 10.8.0.1003 ; ssd magician performance optimization once more and sequential write is ~230-240Run Registry Editor (Start -> Run -> regedit -> enter)
Once in the Registry Editor expand "HKEY_LOCAL_MACHINE"
Next Expand "SOFTWARE"
Next Expand "INTEL"
Click on "Infinst"
On the right hand side there will be two things to look for.
First is to make sure the line that says "Install" has the word "success" next too it (to the right, under "data" ). This indicates the driver was installed correctly.
Next find the line that says "Version", and that will be your version number that was installed.
Also there is a newer RST, grab that from Intels website and install.
RST is updated.We'll we're going in the right direction. Did you update RST as well?
If you give me a couple of hours to finish this PC, when I'm back on my rig I'll upload my CDM scores. As our systems are very similar it should provide you with a good comparison.
My RAM is 1333. No point getting anything faster on an i3.
CrystalDiskMark 3.0.1 x64 (C) 2007-2010 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 505.744 MB/s
Sequential Write : 228.523 MB/s
Random Read 512KB : 355.331 MB/s
Random Write 512KB : 167.317 MB/s
Random Read 4KB (QD=1) : 25.570 MB/s [ 6242.7 IOPS]
Random Write 4KB (QD=1) : 69.468 MB/s [ 16960.0 IOPS]
Random Read 4KB (QD=32) : 307.818 MB/s [ 75150.9 IOPS]
Random Write 4KB (QD=32) : 66.221 MB/s [ 16167.3 IOPS]
Test : 1000 MB [C: 58.1% (62.6/107.7 GB)] (x1)
Date : 2012/04/08 23:14:00
OS : Windows 7 Home Premium Edition SP1 [6.1 Build 7601] (x64)
Sequential Read : 473.042 MB/s
Sequential Write : 235.741 MB/s
Random Read 512KB : 322.505 MB/s
Random Write 512KB : 194.793 MB/s
Random Read 4KB (QD=1) : 23.732 MB/s [ 5794.0 IOPS]
Random Write 4KB (QD=1) : 67.446 MB/s [ 16466.3 IOPS]
Random Read 4KB (QD=32) : 301.371 MB/s [ 73576.8 IOPS]
Random Write 4KB (QD=32) : 76.146 MB/s [ 18590.3 IOPS]
Date : 2012/04/08 23:21:29
C states obviously have an affect on performance. I will check mine next time I reboot.
All of your read scores are fine, but write scores are all lower.
Unless you are prepared to secure erase and start over I don't know what else to suggest..
