Squealing from brakes, but it goes away
Status
Not open for further replies.
BagOfWalnuts
98
So over the summer I noticed that my brakes are squealing, so I figured, ok time to replace the pads. But what i noticed is that they only do it after the car has been sitting for a long time (i.e. overnight, or while I'm at work), and they only do it for about the first minute I'm driving. It also seems to happen more on humid days...could it just be condensation or something on the brakes?
CRXican
9,062
happens sometimes, mine were squeaking today but had them checked recently and the pads are at least 75% life
have them looked at just to be sure
Gibson486
18,378
4 wheel disc brakes?
It's common. Even on ceramic brakes, there are still metal shavings. On my Mazda, sometimes you would hear this loud squeal when you back up (loud enough for people across the people to notice).
Arcanedeath
2,822
Brake rotors are iron and they rust while sitting and it takes awhile to clean them off and get rid of the small layer of rust / oxidation that builds up after they have been siting awhile and this is generally what causes the noise but once you've scraped that layer of oxidation off the noise goes away.
pcgeek11
22,391
5,004
This! Surface rust. No worries.
Sep 7, 2009
12,960
Even though it's common you can usually get rid of it by taking the pads out, cleaning everything, and using a couple dabs of the disc brake glue on the back of your pads.
pcgeek11
22,391
5,004
That isn't going to help with the surface rust on the Rotor Surface.
Sep 7, 2009
12,960
Even though surface rust can cause some initial squealing, it's often exacerbated by the adhesive for the shims deteriorating. If it's a 'regular' car with normal rotors then reapplying it fixes the squeal most of the time.
thescreensavers
9,916
Glue? adhesive? I am pretty sure its a lubricant
Sep 7, 2009
12,960
http://www.crcindustries.com/auto/content/prod_detail.aspx?PN=05016
If you change the pads on a brand new brake system you'll see that the metal shims behind the pads are lightly glued in place by the factory.
Generally new pads from regular parts stores skip the shims altogether and go with a thicker backing plate...
I'm not sure why, but the shims being slightly loose is enough to cause things to squeak/squeal... I actually just helped a friend with an '08 sentra w/ 30k where the dealer etc etc could never get the squealing to go away. It used to only happen when cold for a few min after driving (similar to OP) but after putting a little dab of the disc brake quiet stuff between the pad and shims every noise is gone (along with cleaning up the pads, rotor area etc). The dealer told her the same crap.. It's surface rust blah blah..
I've done this on at least 5-6 cars with great results.. High performance brakes it doesn't make much of a difference, any type of commuter or regular car it does.
Edit: BTW, the spray on stuff sucks and doesn't work for long at all. Get the orange thick goop like I linked..
Sep 7, 2009
12,960
The brake grease is ok, but in my experience needs reapplied after a few months.
The orange goop dries to almost a rubber substance. I apply it very lightly, about two dime sized thin drops after cleaning everything. Put it back together, start car, apply brakes firmly to squeeze everything together and then let sit for a few hours to dry. Voila, no more squealing.
thescreensavers
9,916
Which grease have you used? If you apply too much it can get squeezed out. I used Sil Glyde, las week so I wonder how it will work in a few months. I do know the stuff that dealer put on my car was crumbling when I cleaned it off, so I have no idea what they used. hopefully there isnt an issue.
Sep 7, 2009
12,960
I don't know the brand, I usually go for full syn or otherwise high quality stuff.
Per most service manuals you are supposed to use grease only if you have 'floating shims'... Otherwise you should use the goop.
Note that I am not talking about the 'guiding arms' on the pads, or the sliding pins... I'm talking about a couple of dabs between the pads, the shims, and the caliper.
Status
