squeaky noise when AC turned on + engine revving
Status
Not open for further replies.
andylawcc
18,183
so I start to notice my car will emit a squeaky noise after I turn on the AC when the car has just started. The noise gets louder as I rev the engine higher. After a short while, the noise will go away. So some sort of belt need to be changed or lubed?
ballmode
10,246
this happened to my WRX last summer. My A/C pulley wasn't spinning like it should so the belt was squealing/slipping and the bearings were going out.
A simple 15 dollar part and about an hour replacing it was all it took. Not sure what car you got
Wingznut
16,968
Has to be the belt needing replacement. Possibly tightened, if that's an option. But if the belt is old, you should just replace it.
The A/C clutch issue would not allow the noise to go away after a short while.
BUTCH1
20,433
1,769
Yes, apply a generous slathering of WD-40 over everything, belt, pulley's, rollers, this will quiet thing down quickly!..No, JK, probably just need a new serp. belt, what's the mileage on the car?, In a LOL related story I used to work for a TV repair shop and a guy had a VHS that was squeaking and he actually pushed in the door of the unit and blasted "half a can or so" in his words, into it then brought it in for service when it wouldn't work. This was back in the early '80's when a decent VCR was still around $400..
Status
