squeaking sound when braking in reverse
Bacardi151
540
i get this high pitched squealing/squeaking sound whenever i step on the brake when i'm in reverse (i.e. backing up from a parking spot etc.
i dont get this when i move forward and brake.
anybody know why this is. i want to go to the mechanics knowing what the problem is in before hand so i dont get lured into paying for additional services that i didnt have to.
car: accord 01
Aug 26, 2004
14,685
they might be worn out...or they may just be cheap pads...i got the cheaper pads for my car to begin with...big mistake...after about 1k miles they started squeaking...either way though...sounds like you need new pads
VirtualLarry
56,587
10,227
I get the same thing. Kind of a squeaky-squealy metallic screech when braking while backing up the vehicle. I also occasionally get a repeatable metallic noise when driving along, somewhat less or more depending on if I'm steering left or right at the time. Yeah, I probably need new brakes. Asked the mechanic where I took it last, he said current brakes were fine, and tried to sell me a set of ceramic pads for $300 if the noises really bothered me.
I'm concerned though, had a problem with half of the calipers on the front disc brakes freezing up, so only half of the brake pads got worn, the other half looked perfect. When that happened before, it started with a small metallic squeek, but eventually degraded quickly into evil grinding, and eventually the rotors had to be replaced. Supposedly, the frozen calipers were fixed, but.. the similarities between what happened then, as a precursor, and what is happening now, are scaring me. But unlike before, I still have most of my braking power, and the metallic noise doesn't get significantly worse during the actual act of braking. So I dunno here.
I don't own a garage nor a hydraulic lift, nor know anyone personally that does, and I didn't really feel like doing a lot of work on my car in the winter in the cold, so I haven't taken a look at the calipers/pads myself. Guess I should now that spring is almost here, it's my male duty to fix my damn car squeeks myself. Computers, I can deal with in my sleep, but I'm still mostly an automotive-repair n00b.
Just a curiousity: on an automotive-repair difficulty scale, making an analogy to cooking, where does replacing disc brakes fit? Closer to cooking toast, or making meatloaf, or omelettes, or what?
I think I need a new exhaust system soon too, MA winters aren't too kind to cars. My driver's side door is rusting out on the bottom a tiny bit now too I noticed. Is something like that fixable, or should I attempt to source a complete replacement door from a junkyard, or is that just a sign that my car is now officially a junker and that I've owned it too long, compared to some of you? It's a '92 Dodge sedan, btw, "new to me" about three years ago. Ran like a beaut, but I'm.. not the greatest at maintenance, apparently.
