SQL Stored Procedure Loop
lo5750ul
744
Hey all,
I would like to do a simple counter loop in an SQL Stored Procedure. I am passing a variable in to the SP and I want to count from 1 to the variable.
Does anyone know how to do it?
Cheers.
SQL
115
Several ways depending on which database.
Stripped down SQL Server:
declare @count int
select @count=1
while(@count<=@var1)
begin
print @count -- or select @count works as well
select @count=@count+1
end
lo5750ul
744
SQL,
Thanks for the reply. I had worked that bit out. The next question is, how do you take the counter and create a variable name with it.
e.g. DECALRE @strInput + count to end up as @strInput1, @strInput 2 etc.
