sql select statement for range of dates
TechBoyJK
16,699
60
Hi,
I'm working on the admin section of a website i'm building, and I'm trying to build some queries that get stats of record changes.
Basically I want to query how many records exist that will fall within certain date ranges.
so far, if I want to find records where a datefield has a value within the last month I use something like this
WHERE last_login_date > DATEADD(month,-1,GETDATE())
I'm still trying to figure out the best way to select other dates.
I need the following ranges
within the current day. even if its 1am on tuesday and the day is only 1 hour old, only stuff that matches today/tuesday
within the past hour
within the past 24 hours
within the past week
past month
past year
is dateadd the best function to use?
JavaMomma
701
dateadd is probably good, this is a query that will select everything on the current day - this is ugly though.
SELECT * from foo where
last_login_date > CAST(CAST((CAST(getdate() as binary) & CAST(0xffffffffff000000 as bigint)) as binary(8)) as datetime)
TechBoyJK
16,699
60
i think that select statement just made baby jesus cry
there has to be a better way?
JavaMomma
701
Ya, made me cry as well.. try this :)
SELECT * from foo
where last_login_date > CONVERT(CHAR(8), GetDate(), 112)
TechBoyJK
16,699
60
SELECT * from foo
whats the 112 for?
KLin
30,952
1,080
Dateadd is what you want to use since it can handle different time/day increments. You can also use the style of 101 with a datatype of char(11) too within the convert when seeing logins for the current day.
Hyperblaze
10,027
please tell me you wouldn't use this on a production environment?
KLin
30,952
1,080
Hey if it works. But I agree, someone else would come around and see this and would say "what the hell?!?!" :laugh:
Hyperblaze
10,027
Okay, there are a few other requirements needed other then "it works!"
such as
1) load time
2) server load
3) efficiency
first suggestion is to get rid of "select *"
you should never EVER use "SELECT *"
unless of course you don't care about preformance
JavaMomma
701
I wouldn't use it even though it is apparently fast. It is just way to ugly... found it on some blog.
I agree don't use "select *"
Hyperblaze
10,027
curious question, what do you find "ugly" about it?
JavaMomma
701
The syntax of the casts look ugly yes, but that isn't a big deal.
It isn't very clear that this returns todays date. Also, it makes an assumption that the hardcoded binary value 0xffffffffff000000 when &ed with the getdate() will generate the wanted value... Using a built in API calls would be safer. I feel ashamed for originally posting that code without thinking about it...
Snapster
3,916
Am I the only one who uses a Unix time stamp for time/dates?
Nope : ) I've seen too many nightmare scenarios of differing US/UK server environments ...
Hyperblaze
10,027
just a word of precaution.
if you post code like that a few without further information
1) people assume it's your code
2) people assume you approve of this code even if it's ugly (which in turn doesn't reflect good light on you)
