SQL reporting help needed
RedChief
533
So I have a bunch of usage data. This data is broken down by customer and by period.
For example customer A has a usage amount of 330 between 3/15/09 and 4/13/09 (dates are stored in both mm/dd/yyyy format and Year/day of year format (so 3/15/09 would be 2009074)).
Now the date period varies from one customer to another and the length can vary from 4 to 45+ days.
Each customer has a cutoff date. With that cutoff date, I need to know the average usage for the 6 30day periods before the cutoff and the 6 30day period after the cutoff.
Any suggestions on the route I should go here? Anything in the OLAp/Analysis Services that can help?
imported_Dhaval00
573
I am sure if you post more details, folks here will be able to come up with effecient queries. I am alluding ot the structure of your tables.
Also, you mentioned OLAP/SSAS - are you working on a cube, and you are struggling with MDX queries? Again, please post the details of your backend schemas.
