SQL Question
lozina
11,711
8
Suppose you have the following situation,
a table named 'activity' with three columns as follows:
PAGE_ID - NUMBER
USER_ID - NUMBER
LAST_ACTIVE_DT - DATE/TIME
a web site which has server side code which inserts/updates a row in above table each time they visit or revisit a particular page.
now, you want a report where you get the the last active page the user was on.
how do you do this in one select query?
I cannot do:
select user_id, max(last_active_dt) from activity group by user_id
because while the resulting date would be correct I have no idea what page it was associated with
then I cannot add page_id into the group by expression because then it would separate the results by page but I only want the one last page a user visited and the date of that visit.
Example: data as follows: (bah, attach code is teh suck)
PAGE_ID | USER_ID | LAST_ACTIVE_DT |
1 | 1 | 7/10/2008 |
2 | 1 | 8/15/2008 |
3 | 1 | 7/25/2008 |
2 | 2 | 9/15/2008 |
4 | 2 | 8/10/2008 |
And the result of query would be:
2, 1, 8/15/2008
2, 2, 9/15/2008
Hmongkeysauce
360
Probably something like:
SELECT DISTINCT(user_id), page_id, MAX(last_active_dt) FROM activity GROUP BY user_id, page_id
Crusty
12,684
SELECT user_id, page_id, MAX(last_active_dt) as access_time FROM activity GROUP BY user_id, page_id ORDER BY access_time DESC LIMIT 1;
MrChad
13,507
SELECT user_id, page_id, last_active_dt FROM activity WHERE last_active_dt = (SELECT MAX(last_active_dt) FROM activity a WHERE a.user_id = user_id)
lozina
11,711
8
Although this query didn't exactly achieve the results desired you get the prize because it led me to a query that seems to work. the original query was only returning one row for the entire table, just the very last person who had any activity, but I needed a record for every unique user. So I went with this:
select a. page_id, a.user_id, a.last_active_dt
from (select user_id, max(last_active_dt) as last_active_dt
from activity
group by user_id) x, activity a
where a.user_id = x.user_id
and a.last_active_dt = x.last_active_dt
order by a.edit_user_nm
The key being from your query you use the date as sort of a key which works here because the date is a timestamp with very fine precision so the chances of two people recording rows for the exact same timestamp are virtually impossible. so that's why it works, thanks!
Cogman
10,286
147
Why not do a Select * from blah. Since you want all the data anyways.
lozina
11,711
8
I needed one row for each user. The data has multiple rows per user but I just wanted the one row that has their most recent activity, for each unique user in the system.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Select
activity.PAGE_ID, activity.USER_ID, activity.LAST_ACTIVE_DT
from
(Select USER_ID, max(LAST_ACTIVE_DT) as LAST_ACTIVE_DT from activity group by USER_ID) lastactive inner join activity
ON lastactive.USER_ID = activity.USER_ID AND lastactive.LAST_ACTIVE_DT = activity.LAST_ACTIVE_DT
