SQL ORDER By - two fields
lo5750ul
744
I have a table with two columns of data (Data Type varchar and bit). I want to row sort the data by column two descending and then by column one ascending.
My SQL query thus far is:
SELECT *
FROM MyTable
ORDER BY column_two DESC, column_one
but the data is not sorted in column one.
I really need some help with this one.
Cheers.
Descartes
13,968
What do you mean it's not sorted in column_one? It sorts *first* by column_two, *then* by column_one. Both columns can't be sorted independently because you're sorting rows, not columns.
Croda
178
Ummm...unless I'm missing something, you can't sort by column_two in this case because you only have 2 columns. After ordering by column_one, there's nothing left to order. If you had a third column (column_three) you could
Order By column_one DESC, column_two
You can't sort by both columns if you only have 2 columns.
Imagine this.
Varchar Bit
A 1
L 0
D 1
Order By Column_one DESC gives:
L 0
D 1
A 1
You can't then go back and sort by Column_two because it would have to screw up your first sort on column_one.
Hope that made sense.
L00PY
1,101
Can I be picky and claim Descartes was right the first time, but wrong when he said Croda said the same thing?
You can a different result sorting the second column of a two column dataset.
Example:
A 0
A 1
D 1
L 0
Order By column_two DESC, column_one
A 1
D 1
A 0
L 0
Order By column_two DESC, column_one DESC
D 1
A 1
L 0
A 0
Something is still left to order after sorting the first column, it's just any subsequent ordering takes place after the initial ordering.
Descartes
13,968
<< Can I be picky and claim Descartes was right the first time, but wrong when he said Croda said the same thing? >>
Sure! :) Picky is good.
I still see that I said the same thing, but maybe that's all in my head. I simply tried to explain the fact that the second column in the order by cannot be sorted independently of the first.
lo5750ul
744
Hi guys,
Thank you for all your input. Let me tell you that none of you are right. ;)
I want to sort a list like the one below so that is looks like the second one below. After doing quite a bit of research I found that the reason it won't work is because you can not do a sort properly with a bit Data Type. I changed my it to a TinyInt Data Type and my SQL worked.
B....1
B....0
A....1
C....1
D....0
C....0
B....0
C....0
D....0
A....1
B....1
C....1
joohang
12,340
I just played around with a sample table on my SQL 2000 Enterprise Manager.
Your original SQL statement seems to do exactly what you want. At least on my machine.
My data type was bit, fyi.
