SQL help with count after group by
rh71
52,844
1,049
Have a Device table and a Batterylife table which captures the battery percentage of devices at the same time every day. I'm trying to display the average battery life per device as well as (and here's the issue) give a count of how many devices were captured within the time frame I'm trying to display.
Device Table:
DeviceIDDeviceModel
1iphone 10
2iphone 13
3galaxy S22
4galaxy S9
Batterylife Table:
DeviceIDRecordedDateTimeBatteryPercent
16/9/22 12:00:0088
26/9/22 12:00:0094
36/9/22 12:00:0096
46/9/22 12:00:0093
16/7/22 12:00:0066
26/7/22 12:00:0072
16/5/22 12:00:0055
26/5/22 12:00:0043
36/5/22 12:00:0066
46/5/22 12:00:0067
Current query:
SQL:
SELECT d.DeviceModel, avg(b.BatteryPercent) as Percent
FROM Device d INNER JOIN Batterylife b on d.DeviceID = b.DeviceID
WHERE b.RecordedDateTime > '6/7/22 0:00:00'
GROUP BY d.DeviceModel
Which produces:
DeviceModelPercent
iphone 1077
iphone 1383
galaxy S2296
galaxy S993
Now I want to add a "count of devices" column (as theCount) that was included in the time constraint of the query (of 6/7/22 onward), which should look like this since only the iphones were recorded 2 times since 6/7/22:
DeviceModeltheCountPercent
iphone 10277
iphone 13283
galaxy S22196
galaxy S9193
I can't figure out how to adjust the above query since if I just add a select count(d.DeviceModel) in there, it actually counts all the rows regardless of the time period I queried. I'm thinking I need a subquery of some sort but what I've tried results in counting ALL the rows just the same.
mooncancook
2,874
50
I don't see any reason why count doesn't work here. Just try a simple `
SELECT DeviceModel, COUNT(DeviceModel) AS theCount FROM Device GROUP BY DeviceModel`, you should get count per model. Should be no different if you add the COUNT to your existing SQL
Cogman
10,284
138
You can, in fact, just add `Count(1)` or `count(*)` and that will work with the group by statement to count each row present in the group.
