- Oct 24, 2005
- 3,395
- 277
- 136
Here is my code to connect
############### Code
<?php
$host="localhost"; // Host name
$username=""; // Mysql username
$password=""; // Mysql password
$db_name="orderofb_test"; // Database name
$tbl_name="orderofb_test.members"; // Table name
// Connect to server and select databse.
mysql_connect("$host", "$username", "$password")or die("cannot connect");
mysql_select_db("$db_name")or die("cannot select DB");
// username and password sent from signup form
$myusername=$_POST['myusername'];
$mypassword=$_POST['mypassword'];
$sql="SELECT * FROM $tbl_name WHERE username='$myusername' and password='$mypassword'";
$result=mysql_query($sql);
// Mysql_num_row is counting table row
$count=mysql_num_rows($result);
// If result matched $myusername and $mypassword, table row must be 1 row
if($count==1){
// Register $myusername, $mypassword and redirect to file "login_success.php"
session_register("myusername");
session_register("mypassword");
header("location:login_success.php");
else {
echo "Wrong Username or Password";
This is the error message I receive.
Warning: mysql_connect() [function.mysql-connect]: Access denied for user 'nobody'@'localhost' (using password: NO) in /home/orderofb/public_html/php/checklogin.php on line 11
cannot connect
I changed all the permissons to 777 and I still receive this error.
Is this the correct table name? Here is a pic of my phpmyadmin
<?php
if($count==1){
else {
cannot connect
