SQL and Excel?
DCypher
320
Ok, anandtech, heres the deal. I have an excel column full of alphanumeric ID's. These people have email addresses that correspond to their ID. For example if the ID is bob5, the email address is bob5@john.com. What I want to do is email all of these ID's, first by extracting them and adding @john.com on the end, and then outputting them (probably in a .txt or .doc) and putting them in email format so that I can copy/paste it in the TO: box.
Example:
bob4@john.com; ghu7@john.com; hty3@john.com
I would appreciate any advice, should I use SQL somehow? Thanks everyone.
Jeraden
well, if you just want to suffix them all with @john.com
If the email is in column A of an excel file, in column B just put the formula =concatenate(a1,"@john.com;") then copy that all the way down. Now column B will have the full email address. Now you can copy the contents of those cells and put it into your mail program, though everything will show up on a separate line, but that should be ok depending on your mailer.
DCypher
320
Wow, you rock, thats exactly what I wanted. Thank you so much.
Just for some futher interest, is there a way to extract data from an excel document using SQL?
Thanks again for the help.
cleverhandle
3,566
I think you're misunderstanding what SQL is. SQL is basically a way for applications to talk to a database (on an SQL server). Excel is one such application - it can query an SQL server to get information for its cells. But Excel is not itself a database, it's a spreadsheet - it doesn't make sense to "use SQL on an Excel document".
MrChad
13,507
You could import your spreadsheet into an Access database, then use SQL to extract specific data out of it. But you cannot use SQL directly on an Excel spreadsheet.
