Spybot - Search & Destroy 1.2 problem
hi,
i am using Spybot - Search & Destroy 1.2. When i run check for problems my OS crashes! Its a blue screen which says
"STOP.........
IRQL_NOT_LESS_OR_EQUAL ...
Address 80446BD9 base at 80400000, Datestamp 3eebc002 - ntoskrnl.exe "
any idea?
Try a reinstall, cant hurt.
Is everything ok when defragging, running antivirus scans etc? Hows your CPU temps doing?
i have download the Beta version, 1.3,
same problem!
BLUE screen...
"stop.... ....
an attemp was made to write to read only memory...
It seems to be more like a hardware problem to me. Have you tried running Prime95 to test system stability? Somehow I doubt that Spybot is directly causing all the BSOD.. it's probably more like heavy disk access from Spybot checks that triggered it.
everything works well except for spybot..!
