springy not hard hair gel?
dpopiz
4,454
I got a bottle of tigi bedhead power trip gel and it's pretty good, but it still makes my hair a little more hard and crusty than I'd like it to be. is there a kind of hair gel that makes the hairs sort of spring back and curl up without making them hard and crusty?
Amused
57,354
19,534
"springy?" "hard?" "crusty?"
You sure you're talking about hair?
brigden
8,702
Originally posted by: Kevin
Dry your hair completely before putting the gel in...
This is true.
Or, try using a wax, pomade, or fibre putty. There are literally hundreds of products available.
Kevin
3,995
Bed Head is some good sh-t so its going to keep your hair very stiff. I use Dep Sport (10) for maximum hold. I'd try something lower maybe a 5 or below and see if you get the results you want. Water is going to make your hair shiny and pretty stiff...
