Spray paint problem
thescreensavers
I made somthing out of wood sticks and so I spray painted it black and after 12 hours of drying its very sticky and paint comes off a little is there any thing that can cover this sparay pain and make it not sticky?
Is the paint made for wood? Did you prime?
EDIT: And don't spray anything over it, it'll make it worse.
You're gonna be sanding it off and painting it again. Prime it next time, and use better paint.
Originally posted by: thescreensavers
noo Well I can rebuild it it will jsut take time. I
are u sure there is nothing i can poot over it? if not then I would have to coat it wiht hot glue or rebuild it.
Where did hot glue come from? Just sand what you have, prime, and repaint. More light coats are better than a few a thick coats.
First it's got to dry.
Poot? LOL.
Pics, btw.
And yea, just do it over.
