The Pentium Guy
For my school project, I'm designing a CPU cooler, and I just thought of an insane idea:
Spray cooling.
You can buy these little water-evaporators that take in water and convert it to fine particles of mist. That mist can be sprayed onto a highly-conductive plate that rests atop the CPU.....and then it evaporates.
I have 2 choices at this point:
1) Let the liquid dissipate into the air (possibly ducated outside of the case)
The liquid would have to be water in this case, I don't want to be breathing chemicals in my room.
2) Reuse the liquid
Any suggestions on what to use as a liquid first of all? Water? Ethanol? Dilectric fluid? Something with a high heat capacity anyways.
The evaporated fluid will obviously be in a gaseous form...so I'll need to cool it and then compress it. About compressing it, aren't compressors expensive?
Any suggestions would be greatly appreciated, I'm facing crossroads here and I just need a little push.
-The Pentium Guy
Spray cooling.
2) Reuse the liquid
-The Pentium Guy
