This is a strange one...
I have two identical Seagate 160Gig hard disks. Connected on the primary 80 pin IDE cable and set to master and slave via the jumpers. Each one is partitioned identically - a 40Gig FAT32 partition and the remainder of the drive NTFS.
99 times out of 100, the system boots int XP Pro with no problems whatsoever.
However, once in a while the red IDE LED lights up permanently and the BIOS says there are no drives attached to the system. Once this happens, no amount of powering down and restarting will rectify the problem.
However if I disconnect either one of the drives and re-boot, the other one appears. I can then power down, reconnect the other drive and everything is back to normal.
Over the months I've tried everything, including fitting new IDE cables, new 400W PSU, swapping the drives over so the other one is C: and installed XP on that one, updated mobo BIOS - all of which haven't stopped the problem.
(According to an on-line PSU calculator, my system isn't underpowered with a 400W PSU).
Both drives show no faults with error-checking software and both work faultlessly when in the machine on their own as do they with a *different* HD as primary slave, so I can only think that there's some compatibility problem when they are both connected together.
Can anyone confirm the possibility of this being true or suggest a remedy please?
Thanks...
Baz
System Specs:
Asus K8V SE Deluxe
Athlon XP64 3200+
1.5Gig Kingston DDR
2 x Seagate ST3160021A HD (160G)
Chaintech nVidia FX 5900 XT
LG CD Writer
LG DVD Writer
SB Audigy Player
Thanks...
Baz
System Specs:
Asus K8V SE Deluxe
Athlon XP64 3200+
1.5Gig Kingston DDR
LG CD Writer
LG DVD Writer
SB Audigy Player
