- May 31, 2005
- 10
- 0
- 0
We have a computer which spontaneously powers off within 10 minutes of booting.
If I immediately try to reboot afterwards, the system will either 1) hang just before the point when normally searches for a boot record (i.e. it doesn't display normally seen "Searching for boot record from floppy" message) or 2) it will not even POST.
I have to wait a while before I can sucessfully boot to XP again. After that, I get another few minutes before the next power off. And so on...
Do you guys think this is a cooling problem or a power supply problem or something else? I replaced the power supply and the case fan, but the problem persists. There is a dusty looking AMD heatsink sitting over the CPU -- perhaps that is the culprit? However, the temperatures seem stable (although they are not low: 57oC CPU, 45oC case).. System info follows:
Antec SmartPower 350W
Gigabyte GA-7VTXH
Athlon XP1600 (1.4GHz)
XP Home SP1
BIOS hardware monitor:
CPU Temp: 57oC
Case Temp: 45oC
Fan Speed: ~4800RPM
Vcore: 1.728 or 1.712 (switches between these two values)
Vtt: 1.232 or 1.248
+3.3V: 3.280 or 3.296
+5.0V: 4.838 or 4.811
+12.0V: 12.096 or 12.160
5VSB: 5.053 or 5.026
Thanks for your suggestions.
Gigabyte GA-7VTXH
XP Home SP1
CPU Temp: 57oC
Case Temp: 45oC
Fan Speed: ~4800RPM
Vtt: 1.232 or 1.248
