Splitting the TV cable signal
kag
1,677
www.boloxe.com
I bought a splitter so I can have cable on two TVs. I bought a Philips four-way splitter that said "24k Gold Plated Connections". It was the only one on the shelf that looked "high quality", if I could say that.
I tried to see if I could see a difference in the image, and I couldn't really tell. But usually when is it a good idea to add a signal amplifier? If I have a four-way splitter and I only use two outputs, am I going to have the same signal strenght as if I would have a two-way splitter with both outputs used?
I also got "RG6 Quad Shield" coax cable, which seems to be also of good quality. What does that mean?
T3C
5,324
You should be fine and notice no real diffrence at all. At least from my experince.
I have one cable line coming in. Split into two "installed by cable guy. I then took one of the leads off the spliter and split it again, One going to cable modem the other going to the TV. I have 2 TV's and my internet all running off spliters. You should be fine.
kag
1,677
www.boloxe.com
One thing I only thought on my way back, is that the TV was previously connected to the wall with a cable that the cable guy installed, which is really thick. I bought a new cable to use for my second TV to the splitter. But I forgot to buy a good short cable to use from the wall to the splitter. I used an el-cheapo cable that I had here... maybe that could be deteriorating the signal.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
If you're using a four-way splitter, then it spits the signal four-ways, whether you're only using two (or three, or one).
Either get a two-way split, or at least get some terminators for the unused ports. They'e cheap, and frequently sold in two or four-packs.
If you decide to use an amplified splitter (really a four-way amp), then it should go into the line as early as possible. If you're using a cable modem, then you can either do a two-way split, amp one side for TV, the other side goes directly to the cable modem ....
OR
You can get a bidirectional amp (4-way ~US$75-100) and put it inline immediately after the cablecome into the house. Feed all lines (TV and Cable modem) from the taps of the amp.
Good Luck
Scott
Kenazo
10,429
Scott
Are you sure about this? Doesn't the splitter just splice in a parrallel connection? In which case there is only going to be a change in resistance if the parrallel circuits are complete, thus if only two of the 4 connections are used, it is not as poor off.
Keep in mind that I don't know how these splitters are made, just how it should work based on my understanding.
ScottMac
Mar 19, 2001
5,471
Yes, I'm sure. It's a passive splitter, it's a power divider, that's it's job.
If you look at each of those "out" connections, you're likely to find a legend that says something like "-7.5" or some similar number from "-6" to "-8.5" That's the db loss per connector (whether something is connected or not, theat's the drop of each connection).
-3db represents half of the input power, a four-way split shold be ~ -6db, plus the loss of the connectors and the splitting network (could be ~.5 - 1.5 .... depends on the quality).
Leaving the unused ports unterminated *may* have negative side effects (noise mostly), as a matter of practice, they are usually terminated (little caps with an "F" connector and a 75 ohm resistor across it).
Good Luck
Scott
EyeMWing
Banned
Jun 13, 2003
15,670
You don't need power amps until you have about 6 outlets (I have 14. Reception at the end of the tree is HILLARIOUSLY poor)
