Splitting PWM 4pin Fan Connector
UaVaj
1,546
http://www.ebay.com/itm/280553936724
how much amperage/wattage can a typical motherboard PWM 4pin fan connector deliver? in other words how many 140mm fan can one safely run off a single the PWM 4pin without frying the motherboard.
MB in question is ASRock Z77 Extreme4. looking to run three 140mm PWM fan for CPU cooling.
DesiPower
15,299
740
The motherboard manual should tell you the amperage or something related, following formula might help you determine whatever information that might be lacking...
Watts=Volts X Amps
iirc, generally fan use less than 1 amp, typically around .5 not more than .7 or .8 max..
Eureka
3,822
Most (but don't quote me, so verify it within your manual) modern headers should be good to up to 1A on each header. Each 140mm fan should be around .2-.5A, depending on how fast the fan can spin and how big the blades are.
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
I wouldn't do more than 2 fans on 1 fan header. Asrock does not provide specs but I can tell you that I can safely run 2x 140mm fans no problem.
BrightCandle
4,762
I have seen motherboards go up as higher as 4A, but 1A is much more typical.
If you are going to start grouping fans together you might want to consider a fan controller which will often put out 5A or more per channel. I do this on my water cooling fans (10 of them in all!) so I can group them by radiator and control them together.
Vectronic
489
I tried finding the limits before for Z77 Ext4... since that's how I killed my last board (shorted Cha Fan1 directly, not overloaded)... didn't. So just stick with the 1Amp assumption, it will at least provide/be fine with that.
If I get the time, and decide which PSU I might want to kill, I'll test it with my old board since it still spits out power to the fans. All I really know is that the board doesn't provide any sort of safety/fuse of any kind... normally a board will have resistors in case they are overloaded, burn out the resistor... nope... it'll keep trying to output until it fries a PCB trace.
Going by this, it seems the PCB Trace *could* handle about 2.5A at least to Cha Fan 1... but... yeah.
