I wasn't sure what category to put this in, I decided here. Bare with me as I try and explain this.
Components: PC, Xbox360, Monitor, 1 Ethernet cord.
Goal:
-Take (only) 1 ethernet cord, connect it to something which allows for 2 ethernet cords to connect to it.
-Use the two new cords to connect both the Xbox360 and the PC together - allowing both to use the internet at the same time.
-Also allowing the Xbox360 to detect a PC and allow me to stream things like music through the Xbox console.
I probably wont use both components at the same time but its annoying to be manually unplugging the PC and Xbox every time I want to use it. Its also annoying having to burn a measly 18 songs at a time to the Xbox360 Hard Drive from a CD and would rather stream music from the PC to the Xbox through the "Connect Xbox to PC" option in the Xbox options.
Any idea on a component that would do this for me? Thanks.
Here is a picture to better illustrate my point:
http://img232.imageshack.us/img232/7262/85994803jp3.png
Goal:
