Spilled water on my laptop, keyboard messed up, help!
Jaanpunjab
39
I knocked a glass of water over onto my laptop and everything seemed to be fine, but now the 'p' button has stopped working (luckily I have a desktop PC too). Anybody have any ideas of ways to fix it, copying and pasting every time i need a 'p' on my laptop just isn't gonna work for long.
SuperNaruto
997
what kinda notebook ?
if dell, u can buy keyboard on ebay for like 25 bucks.. i done it a few times
herm0016
8,522
1,131
you turned it off and let it dry out right? if not... well your not too smart. but if you did you should be able to just take it apart and clean it out. may be some corrosion from the water. if you did leave it on you will have to replace the keyboard becuase it probalby shorted out, consider yourself lucky that you did not fry the MB also.
Oyeve
22,071
885
Yep, coworker spilled water on her lappy. Idiot turned it on. $1000 repair job.
Harvey
Administrator<br>Elite Member
73
If you can remove the keycap for the non-working key, you may be able to spray some contact cleaner into the switch. Do this while continuously pushing the actuator of the switch.
If you don't have any contact cleaner, and it's so fubared that it's already a loss, you can try using WD-40. Use a very light touch on the spray valve, keep a Q-tip close to it to block any excess spray, and use the extender tube to get it only in the switch.
I've fixed many failing and near failing keyswitches this way, but it's always a toss of the dice.
Good luck. :)
Jaanpunjab
39
Haha, yeah, I turned it off and let it dry out. I'll have to try out your suggestion Harvey, if that doesn't work I'm glad to hear you can find replacements for cheap.
BladeVenom
13,365
16
Use a fan and maybe compressed air to make sure you get all the water out, and it's completely dry. Maybe a good hair drier on blow only no heat.
I'll assume it's already unplugged with the battery removed.
Harvey
73
Umm... That's one out of two. If you can't clean the contacts, it's somewhere between very difficult and impossible to replace a keyswitch on the keyboard assembly, and replacing the whole assembly is usually pretty expensive, just because the manufacturer will probably charge a lot for it. You'll have to check with your local repair facility.
