SpeedStream Wireless PCMCIA SS1021 @ JustDeals.com
Features:
Up to 11 Mbps for true,high-speed networking
Compact,integrated design separate antenna required
Supports Strong WEP Encryption for network data security
Plug and Play installation
No external power supply necessary
Wireless network access for notebook PCs affords true omputing mobility
Provides wireless access for desktop PCs when used in conjunction with the SpeedStream Wireless PCI Adapter (SS1023)
Ideal for apartments,offices,and dorms where running new wires is not an option
Full 802.11b compatibility lets you access popular wireless network in airports and other public locations
Specifications
Form Factor: Type II PCMCIA card with built-in PCB patch diversity antenna
Power Consumption: 3.3 V,350 mA TX,230 mA RX,20 mA Standby
Host interface: Type II 16-bit PCMCIA bus
Radio Technology: Direct Sequence Spread Spectrum (QPSK, BPSK,CCK)
Frequency Band: -ISM Band, -2.4 ~2.4835 GHz (for US,Canada)
Operating Channels: -IEEE 802.11b compliant -11 channels (US,Canada)
Data Rate: 1/2/5.5/11 Mbps per Channel
Output Power: 13 dBm ~20 dBm (50 mW)(max)
Receive sensitivity: -Min.-76 dBm for 11 Mbps @BER 10E-5; -Min.-80 dBm for 5.5/2/1 Mbps @BER 10E-5
Typical Operating Range: Indoor:30 M @11 Mbps;50 M @5.5 Mbps;100 M @2 Mbps; 120 M @1 Mbps
LED Indicators: Power
Standards Supported: IEEE 802.11b
Certifications: FCC Part 15 Class B,CE
Warranty: -1 year parts and labor for hardware -Additional year available with product registration
System Requirements:
Available Type II PCMCIA slot
802.11b compliant wireless network
Supported OS: Windows 95/98/98SE/Me/2000/NT4.0
Compatible OS: Linux, others
Features:
Specifications
