Speedstream help needed... wifi card help..
Tbirdkid
3,758
4
I installed my wifi card which matches my speedstream router. I set up the drivers and it seems to be linked and running no problem. However I cant recieve data... i send all day but cant recieve. What do I do to fix this problem? Im sure its something to do with my mac address in the router setup but I am not sure. All the help I can get is much appreciated. Thanks in advance..
IceNineJon
72
This sounds like a stupid question but how do you know you can send but not receive (what are you basing this on...your up/down stats, sending files to another computer on your network, etc)? Do you have any firewall software installed on your machine?
