skisteven1
I just bought a compaq x1000 series (x1058cl), which is a centrino using speedstep. The speedstep works fine on its own, but I thought I read once that it is possible to directly dictate the speed of the processor at a given time. Right now, if I start really working the proc (via prime95), it jumps up to full optimization at 1400Mhz. But if I'm not doing anything, it will drop to 800, 600, or even 300 Mhz, which extends the battery life by several hours. Is there a way to dictate the speed manually? I'm pretty sure you can do it in linux, but I'd prefer to stick with XP Pro.
thanks
thanks
