- Jan 28, 2002
- 8
- 0
- 0
I hope there is somebody out there, that has the above mentioned combination of Motherboard and CPU, that can help me understand if things are/can work correctly.
When the bios loads, it lists the processor as an "Athlon (tm)", NOT "Athlon XP (tm)" as I have seen on screen grabs.
It also lists the speed as 1150 Mhz. When I then enter the settings in the Bios, it lists the speed as 1800 mhz, FSB 133 and multiplier 11.5X. It also here lists the processor without the "XP". I would expect the speed to be 1533 Mhz, but that is not a choice in the CPU speed settings.
I am not trying to overclock, just want the expected performance from the CPU w. standard AMD heatsink/cooler
System: ABIT KR7A-Raid, AMD Athlon XP 1800, 2x512MB DDR, 100gb WD, 27gb Matrox, 64MB Abit Siluro gForce2 MX400, Hercules Fortissimo II sound, DVD and 32x12x40 CD-RW, Pinnacle 1394 card, Windows XP Pro
Thanks
Thanks
