speed of fan pluged into motherboard
realredpanda
205
i have two YS Tech 80mm fans connected to the motherboard,they're 3700rpm,abit faster then the other fans i've used before,can the motherboard handle these ok?
nf7-s
2500barton
512ddr
Cheetah8799
4,508
I don't see why it wouldn't handle them. 3700rpm isn't all that fast. If the draw a lot of current, then you might need to be concerned.
