Speed of DVD/BD/USB2.0 comparison?
mingsoup
How do you compute the speeds of say an "8x" DVD or "2x" BD drive and then say compare it to the speed of USB 2.0? to the speed of a 5400RPM hard drive in a USB 2.0 enclosure.
I am assuming that all hard drives 5000rpm and up, easily exceed the speed of the USB 2.0 cable. I've never understood the 8x/2x media drive specifications or how they relate to actual hard disk/ USB speeds.
Thanks.
Just checked online:
1x CD ~150KB/sec
1x DVD ~1.3MB/sec
1x BD ~4MB/sec
I never get more than around 10-15MB/sec with optical drives on any interface so USB 2.0 is probably fine.
I guess I could check online too. :\
USB 2.0 is rated at 480 mbps (57.2 MB/s).
I checked a 5400 "Green" drive, which would probably have one of the slower sustained read speeds. It was spec'ed at 110 MB/s.
Thus it doesn't matter what you do to your SATA hard drive.....you are always gonna saturate the USB 2.0 cable.
Also USB 2.0 will always be faster than a 12X DVD drive.
It will also be faster than a BD drive. For example....a 2x BD is only ~9MB/s. Thus still slower than USB 2.0.
The end.
Well USB 2.0 for a burner is fine. But USB 2.0 as a external hard drive is horribly slow. This is why you get a eSATA external drive.
It took 40 minutes to create a image of my drive on external with eSATA cable. I tried the USB 2.0 cable and same thing took about 4 and a half hours.
People look at the size of a external wow 1TB or 2TB USB drive for good price and get happy and get it not realizing its gonna perform horribly and probably doesnt have a off button.
firewire is slow too, your hindering performance.. eSATA will be same speed as your internal drive about.... Thanks gg and gb
