Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 415 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
807
1,411
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! :)
Reactions: richardllewis_01
Hans Gruber
2,302
1,216
Still not sure if this was real or not. Saw a few claims it was fake.
The reason why the 5800x3D was limited to 4.5ghz was because of the v-cache memory. AMD believed they were voltage limited on Zen 3. The Zen4 3D v-cache will not have the name voltage limit issues.
If the 5800x3d is golden silicon and the performance limits were removed. I could see a 5.2ghz fully functional 5800x3D CPU.
Kaluan
504
1,074
Yeah... If we're talking about the same thing... the claims were made by Intel slanded people, and not even tech-savvy ones, basically coping people.
I wouldn't put any weight in what such people say, unless they have valid proof.
nicalandia
3,331
5,282
Some Spec numbers with Low end Air Cooling
"Note: The results of the 7950X in the picture are taken from my new ITX machine, which uses AXP90-X47 low-power down-pressure heat sink, so it significantly affects the single-core maximum frequency (the higher IPC sub-item is only around 5.4 GHz)"
13,588
What will AMD do next? Launch Zen 4 on AM4?
inf64
3,864
4,546
There is zero % chance of that happening. AM4 is fine as it is, AM5 just needs more time and a bit better economic circumstances. Intel will face the same problem once they launch their next platform.
HurleyBird
2,759
1,455
It's probably non-zero, but it really depends how much AMD hedged their bets in advance. There was talk of Zen 4 AM4 prototypes, but how far did development get? If AMD knew a year ago what they do now about economic conditions I have no doubt they would also plan to launch Zen 4 on AM4. The problem is that, if there's six months of work left to get Zen 4 AM4 ready to launch, by the time it does DDR5 is likely much cheaper, non-vcache Zen 4 is going to be bottlenecked by DDR4 to some extent, and you've pulled resources from other areas for a prolonged period of time.
That said, if Nvidia can swallow their pride and unlaunch the fake 4080, AMD should be able to swallow theirs and lower prices of at least the 7600X, 7700X, as well as the B650, and X670 chipsets (assuming that chipset price hikes are one of the major reasons for absurd motherboard prices.)
deasd
567
921
Next? Just launch 125$ B650 and even cheaper A620.
Also, don't trust WCCF.
13,588
Intel gamers already in the habit of turning off E-cores and now AMD gamers may want to turn off both CCD and SMT on the 7950X for performance boost.
EDIT: Sorry, already posted few pages back.
Markfw
May 16, 2002
26,129
15,274
eek2121
3,100
4,398
The only thing outselling Zen 4 is Zen 3. I doubt AMD cares much.
Overall demand is weaker across all of big tech.
Abwx
11,536
4,323
5950X/7950X/5995WX HPC comparison at Puget.
64 cores are 64 cores, even lowly clocked and from previous uarch.
Markfw
May 16, 2002
26,129
15,274
They use 4800 for the 7950x. While not offcially spec, even AMD says use 6000 cl30. The other 2 are using 3200 which is NOT spec.
Obviously flawed setup, so the results are half useless.
moinmoin
5,064
8,032
I disagree. The areas Puget Systems tend to test are ones where using ECC memory makes sense which seldom go significantly beyond JEDEC specs. So while not matching typical mainstream DIY specs, it's still plenty useful.
Markfw
May 16, 2002
26,129
15,274
You just put a 25% handicap on the 7950x. And they did not use avx512, which a few applications also do. And 16 cores compared to 64 ? whats that about.
nicalandia
3,331
5,282
Even Genoa ES CPUs are being tested with 5200 DDR5. Why limit the Ryzen 7000 CPUs to 4800?
Abwx
11,536
4,323
If official spec is 5200 non ECC then it looks right that ECC will mandate one bin lower frequency, dunno if 5200 is also supported by the 7950X when it s with ECC.
Anyway it shouldnt have a big influence in things like Linpack, possibly in large compilations.
