Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 6000)
Page 38 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
What do you expect with Zen 4?
  • Total voters
    224
krumme
5,912
1,531
Just to make sure there's no confusion, 22FDX has been mature and shipping high volume for a while now. 12FDX is still in the oven. I'm guessing it gets launched next year or possibly the year after.
Who are the customers? And what is the volume?
Hitman928
3,432
3,614
They have many customers. Most that I am aware of are using the process for analog/mixed signal/RF designs. They also have customers in the automotive space or those who can benefit from using IP that are qualified for automotive environments. For the volume, you'd have to check their financial reports to see if they break it down at all between processes.
NostaSeronx
3,227
754
Well since the volume capacity for 22FDX is in the 100K wspm range. While the volume capacity for 14LPP/12LP/12LP+ combined is <55K wspm. I would say there are more customers for 22FDX and the volume is at least double that of GloFo's FinFETs.
You need to mention Intel 7nm too.
Intel's 7nm has been here. Most of it's been taped out. The GPU, the Atom Forests, and the that's not a moon Cove core, etc. It's really has just been politics at Intel.
- 14nm backports
- 10nm ongoing but also cancelled (Some of these products are actually 7nm backports; if it aint broke on 7nm, it will be broke on 10nm)
- TSMC 7nm parallel ports (X-Gold 806&816 was TSMC 7nm, but also was Intel 14nm for the XMM 8060 and Intel 7nm for the XMM 8160)
- Internal 7nm NPI (Of which, there is a ton of tape-ins(ARM(CPU/GPU/PHY/etc)) from external sources and tape-outs spawned from that)
There is no depeche mode in 7nm.
12FDX so far has been built up for high performance based on: https://www.leti-cea.com/cea-tech/leti/english/Pages/Leti/Projects supported/OCEAN12.aspx
With Rockchip's 22nm: RK3568/RK3566/RK1808
It is very likely that the next process nodes for the succeeding SKUs will potentially be 12FDX. Which unlike 22FDX will have all proposed enhancements at introduction(1.0 PDK) rather than at a + node or a 1.0+ PDK.
For "Zen4" it is best AMD abandons GlobalFoundries. Use TSMC's 6nm for the IOD and the chipset instead. 125 mm2 is too big and they need a foundry with proven Analog/Mixed-Signal shrinks on FinFETs like TSMC. N12 at GloFo -> N6 TSMC -> N4 TSMC is the ideal cost-effective path for the IOD given the need of PCIe 5.0 -> PCIe 6.0 & DDR5 -> DDR6 fast-bring-ups.
Cardyak
45
73
61
...and the that's not a moon Cove core, etc. It's really has just been politics at Intel.
Obvious reference to the Star Wars Death Star here with the "that's not a moon" quote. Which is interesting because many months ago you alluded to a Cove architecture Intel was working on code-named "Deadsun" (Literally a euphemism for Death Star)
Where I found it didn't specify what Cove core it was talking about on the roadmap. Other than it was later rather than earlier, since we only know about Goldencove, I originally had Goldencove in the spot.
Palmcove (10nm) -> Sunnycove (10nm+) -> Willowcove(10nm++) -> Goldencove (10nm+++) -> --- Cove (7nm) -> --- Cove (7nm+) --> "Deadsun 1" (7nm++) -> "Deadsun 2" (5nm)
Panino Manino
389
483
New Xeon numbers are not bad, but don't those results mean that by the end of the year it'll be obliterated by Zen 4 with the new IOD die?
amrnuke
1,155
1,722
I don't think zen4 is expected by end of the year, somewhere mid-2022 is more likely. So, no it will not be beaten by zen4 by the end of the year.
Given November Zen 3 launch, and a 15-18 month cadence, a first-half launch seems likely (Feb-May 2022). Is there any reason to think the cadence has dropped to more than 18 months even as Intel are moving their cadence to a faster pace?
LP-ZX100C
4
Well ,AMD will start ramping up Zen4 (5nm) starting with 2H2021, also ,i think , they'll have products ready for hyperscalers and cloud at the end of the year , and the said launch will happen later.
lobz
1,620
2,084
It's almost as ridiculous as a vaporware as cannon lake.
DrMrLordX
17,031
6,001
Considering how long they sat on Milan, there's no telling when they'll actually launch Genoa. Rome is still faster than Intel's fastest Ice Lake-SP so they're not under a lot of pressure right now.
Ajay
8,328
3,209
But only in Frontier ??
We'll have to wait and see
Although Trento is being designed for Cray, it will also be available to other OEMs/ODMs. The main advantage of this platform is scalability, bandwidth, latency, and of course, the relatively simpler programmability thanks to the use of the Infinity Fabric 3.0 interconnect and a unified memory pool across the CPU and GPU
moinmoin
2,369
2,941
Note that the follow on supercomputer El Capitan, which is scheduled to go live early 2023, is announced to use Epyc Genoa chips. So whichever ways Milan and Trento differ Genoa won't need to be adapted to supercomputer use anymore. (And Zen 4 based products should be available by late 2022 at the latest.)
Considering all the big guys got Milan already AMD effectively just sat on the Milan launch press release.
ASK THE COMMUNITY
