  • Community Question: What makes a good motherboard?
Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 6000)
Page 27 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
What do you expect with Zen 4?
  • Total voters
    199
french toast
981
808
Very disappointing about Warhol IMO, was expecting some mild IPC improvements ~8% and +200mhz clocks, plus new IOD with AM5, seems we are getting another ZEN+.
This may have been taken out of AMD's hands somewhat with struggles to get EUV machines and capacity wars at TSMC.
At the end of the day we all know that having the best chip and technology doesn't guarantee you improve market share and margin, rather capacity and costs play a huge role in that, it seems AMD looked at what's guaranteed to be available at that time frame and figured they would save development costs and get more of the less leading edge wafers at a cheaper price, rather than much less of the more expensive wafers at the leading edge.
Shame on a technical point of view but understandable on the business side of things as AMD already has brilliant chips, - they just can't make enough of them to take market share.
I do feel this is an opportunity missed to crush Intel on the technical side, if Alderlake S comes around in volume H2 2021 then AMD might become the budget option again.
Disappointing but understandable is my take.
french toast
981
808
Well they got quite backfired for paperlaunching both Ryzen 5xxx and RDNA2 so they might not want to stretch it too much.
AMD need to get another supplier going at Samsung, I know they have global foundries for the IOD, but if the want to improve output and market share they need Samsung to produce a portion.
Samsung's process is ideal for low power applications, that is what they have earned their bread and Butter on from smartphones.
By all intents and purposes AMD has a close relationship with their chip division, they should make the laptop chips and future IOD at Samsung to free up capacity IMO.
Reactions: Tlh97 and Thibsie
DrMrLordX
16,761
5,739
Can't say I blame you, but honestly what do you expect? AMD is going to milk their advantage. Also, contrary to my previous assumptions, it may well be that it took AMD longer to bring Zen3 to market than Zen2 or Zen+ (relatively speaking), so they may want to milk it for awhile.
Agreed, though my hope was for Zen4 on AM5 in 2021, which is definitely not going to happen.
moinmoin
2,215
2,632
Do you seriously expect that? With Intel lacking at the execution side for like half a decade now (which over time "helped" it lose all of the advantages it initially had over AMD) I find it hard to imagine that Alder Lake alone will not only make Intel competitive again across the product range but also force down AMD to become a budget option again.
exquisitechar
460
533
Golden Cove is likely something like Sunny Cove in terms of the IPC improvement. The only way it won't make AMD the budget option for a while (bar MT performance when it comes to the 5950x) is if it's pushed back to next year, closer to Raphael than Warhol.
xilli_fiberbit
23
24
41
OK, in that case It's most probably CDNA + HBM + Zen3 on package (considering what they hinted at the announcement and the money that was thrown AMD's way to make software for it)
In frontier Trento CPU will be combined with GPU MI200 (GPU build on MCM/chiplet and (based on CDNA2 ??)), so what is purpose to put CDNA(2) GCD (Graphic Core Die) chiplet on EPYC package ?
inf64
3,127
2,078
So Zen3 which has around 7% higher IPC than WC does not make WC a budget option, but a *possible* IPC lead of around 10% GC might have over Zen3 will make AMD a budget option? That is ridiculous.
Not to mention AMD is a moving target and Zen4 is coming in early 2022, so whatever IPC lead they may have will evaporate quickly. Then there is clock speed, core count, platform features, longevity etc. Intel is in a world of hurt and will be a slower(budget) option until 2024.
teejee
356
199
All of their budget CPU's like 3200G, 3400G, 2600, 240GE, 200GE , 3000G and more are from Global Foundry, so they are using GF pretty well.
dr1337
90
155
66
Heterogeneous compute. Accelerators already work in conjunction with CPUs, its just through (relatively) slow and latent PCIE interconnects. By moving all main components onto the same package you significantly increase communication speed, and you can reap other benefits such as shared memory and shared caches. Basically, the accelerator can load data and work faster by being on the same package. Having memory on package is part of this too. You can significantly increase bandwidth and/or significantly improve latency for both major components at the same time.
Reactions: moinmoin
Ajay
7,857
2,947
Oh and as an aside, it does seem like Warhol is a straight Vermeer refresh akin to the Zen 2 XT skus.
I was hoping it would be AM5 but unfortunately not, seems they're focusing on clocks. Wondering what is possible though given it is possible - even if rare - to get Zen 3 chips clocking above 5GHz already.
Well, IIRC, there are two other performance N7 process nodes still on the table at TSMC (Like EUV). But, if all we get is a +200MHz bump in clocks, Warhol would be pretty lame.
french toast
981
808
Yes it looks like we all expected too much, remember all that 5nm Zen 3 fluff that was doing the rounds on here a few months ago?
I thought I was one of the more realistic ones.
I was in the Warhol being zen 3 refresh on AM5.. Also nope.
Whether we like it or not, gaming seems to dictate which is the premium products on the desktop, why else was AMD the budget option with zen 1 and Zen + when it had more cores and all the other advantages? Single core performance and gaming.
If Alderlake S comes H2 2021, it will easily have the ST and gaming crown, it may also have efficiency crown in some scenarios also, never mind new brand new platform and all the marketing opportunities that creates.
Do we know zen 4 desktop is coming that early? I would argue we won't see 5nm on desktop till H2 2022, one year later than Alderlake S.
Willow Cove might actually beat zen 3 on St and gaming performance, which makes them a premium product in the eyes of the public.
So next year Alderlake S would be the premium product no doubt, which makes anything less from 16 cores from AMD the budget option.. Comparatively speaking.
AMD needs AM5 in 2021 and a solid increase in Cpu performance to keep them up there...i thought Zen 3 + on 6nm was realistic..
True enough, I still think they need to outsource more from Tsmc, not enough capacity there at all for all those products.
Samsung 5nm Lpp in 2022 would be great for laptop and budget GPUs.
exquisitechar
460
533
Hopefully, we'll see Zen 4 desktop by the end of Q2 2022 at least. Willow Cove and Zen 3 are pretty similar in terms of ST performance.
Rocket Lake appears to have pretty similar ST performance to Vermeer. Add 15-20% and Zen 3 desktop CPUs will be firmly the budget option compared to Alder Lake-S if they are to compete.
Reactions: french toast
inf64
3,127
2,078
Rocketlake is still vaporware with no official benchmarks. We had a few leaks here and there but nothing substantial. Like I said, Zen3 has a nice IPC lead over the best Cove there is, so a backported IceLake on 14nm can only clock higher and that is about it. It will have 2x less L3 cache per core than 5800X which is a huge hindrance in gaming.
yuri69
86
*Mobile* WC is about 5% slower than *desktop* Zen 3. Mobile Zen 3 SKUs won't feature that large L3 - WC will be closer.
RL should feature a bit lower IPC compared to Zen 3. OTOH it'll clock beyond Zen 3 - at least those ES do. This combination will target stealing Zen 3 gaming crown. It will probably succeed given its lower latencies in the memory subsystem. That's the point Intel has with the CPU.
There is nothing known about GC besides aiming at "IPC" gains (SC => around 1.2x). This thing being at a newer 10nm revision than Tiger Lake promises some very nice frequency targets. Apparently, Intel targets both 2021 servers and desktop with GC.
It seems nice like a competitive offering. I mean having a modern DDR5, PCIe5 platform equipped with beyond Zen 3 IPC in 2021/2022. Right?
HurleyBird
2,260
694
Probably because of comparison equivocation with Skylake-X and a very low reputation post bulldozer. And where AMD did lose, it was often more than 7%.
Zen 2 still lost in gaming and absolute ST performance but wasn't considered a budget option at all.
Given Intel's execution, I'd be surprised if it came out any time before late Q4 2021, and I'd peg 2022 as more realistic. Shades of Rocket Lake in late 2019 and then 2020. I'd very much like to be wrong, however.
I'd posit that to the extent Alderlake-S is impressive and the extent to which it launches earlier than expected, will help drive the Zen 4 release schedule, and while I won't discount entirely the idea of Zen 4 releasing a full year later, I find that scenario highly dubious except if Alderlake-S seriously underperforms expectations or AMD experiences significant issues with bringup.
moinmoin
2,215
2,632
Just a reminder that Intel still hasn't managed to release any node newer than 14nm on desktop (and even on server that has been repeatedly delayed, maybe we'll see Ice Lake-SP soon).
soresu
1,568
780
I don't uderstand what is the codename Trento for ? An EPYC between Rome and Genoa ?
i wonder what'll be the main difference, DDR5?
Possibly, or CCD cache amounts and sheer IOD capacity (ie more PCIe lanes) I would think.
Maybe also extra IO PHY's beyond what they plan to give Milan like CXL, CCIX, GenZ etc etc - perhaps even baked in state of the art ethernet like 100Gb/s?
DrMrLordX
16,761
5,739
. . . which is probably one reason why AMD isn't launching Raphael until 2022, more-likely-than-not. That and maybe it really is taking that long to pull it together.
HurleyBird
2,260
694
But it does feature a significant better memory controller, and while Renoir had 1/4 of Matisse's L3, Cezanne ups that to 1/2 of Vermeer's.
Most likely mobile Zen 3 will performance will be roughly comparable to desktop. A tad slower overall, but moderately exceeding its desktop counterpart in gaming workloads.
soresu
1,568
780
Huge hindrance is a real stretch.
Anyone truly serious about gaming to the point that this would bother them is not doing so on a mobile APU chip/platform.
inf64
3,127
2,078
We are talking about desktop parts here... 5800X (a desktop part) has 2x L3 cache Vs desktop Rocketlake.
Reactions: Tlh97 and soresu
ASK THE COMMUNITY
