Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 5000)
What do you expect with Zen 4?
  • Total voters
    119
Gideon
677
901
Yes I really hope AMD supports at least a subset of it in Zen3, considering even VIA managed to support it in Centaur, it shouldn't be that hard
moinmoin
1,402
1,191
Probably whatever is supported by Cascade Lake, Cooper Lake, and IceLake/IceLake-SP.
Did you look at the table I linked in your quote? Each of them supports a different selection of subsets, none of them supports them all (not even Tiger Lake).
DrMrLordX
14,592
3,556
Yes. Cascade Lake and Cooper Lake are identical except for bfloat16. That's a reasonable target. IceLake supports a lot more except bfloat16. That's a more-ambitious target.
TigerLake is new enough that copying its entire instruction set may not be feasible.
I think the main point is to forget ER, PF, 4FMAPS, and 4VNNIW.
extide
255
63
101
www.teraknor.net
There's plenty of it in x264, x265, SVT-AV1 and now some in dav1d (therefore by extension rav1e too).
I think some emulators have it too, and I wouldn't be surprised to find it in Intel's Embree which is used in quite a few ray tracing code projects (oddly including one of AMD's).
Not AVX512, though.
soresu
970
296
Not AVX512, though.
I was talking abut AVX512. Look up those things and you'll find the code commits.
Probably more open source uses it than closed.
Reactions: Vattila
extide
255
63
101
www.teraknor.net
Nice, that's happening sooner than I'd hoped.
Hans Gruber
817
193
I will give an opinion base on everything I have read in the media. Zen 3 will be at least a 20% improvement over Zen2. Zen 4 will have DDR5 and built on 5nm. It's too far out to predict. DDR5 could be a big improvement over DDR4.
Reactions: Vattila
Caveman
2,401
10
Just a WAG... Do you think another 20% over Zen 3 is possible?
uzzi38
524
469
I look over to the side a bit and I see AMD claiming a 50% gen on gen (and within 12-18 months of one another) with their GPU stack in terms of power efficiency even without node shrinks.
I think we're looking at an AMD that's dedicated to pushing performance as much as possible. With Zen 4 comes the switch to N5. That alone should allow for more than just a 20% boost in overall performance, and as things stand, I have absolutely no reason to believe they can't do it.
Hans Gruber
817
193
AMD already said they were very happy with what Zen3 has done. Meaning customers will be happy with the results. In an earlier post (here) it was said 20-25% improvement for Zen3 over Zen 2. I think that is probably very accurate. Consider that Zen3 is a new processor vs. Zen 2 that was largely an evolution of Zen with a 12nm and 7nm die shrink. Whether the 7nm +is much better. They said AMD was hoping for more in the new 7+nm similar to the shrink from 12nm to 7nm, but the architecture improvements offset that. The boost they were hoping for in silicon was not as significant as they had hoped.
I should clarify my speculation is based on interviews that I read about from tech websites. Insider information. Sources from Taiwan are probably the most accurate.
Zen4 is too far out. But the 5nm and DDR5 should be significant.
inf64
2,941
1,359
We talked about this before. AMD stated they had a 40% IPC design goal with Zen1 over previous core (last iteration of Bulldozer). They achieved ~52%.
I expect the same goes for Zen3 Vs Zen1 and Zen5 vs Zen3. If they were to achieve the goal for Zen3 (40% higher IPC vz SummitRidge Zen1) then Zen3 just needs 17.5% average IPC improvement to accomplish that.
For Zen5 is a bit trickier since we know nothing about improvements in Zen4, but if they were to be more in the line of Zen1->Zen2 then Zen5 would need north of 20% to achieve that goal. It's very much possible IMO. We are talking here about strict IPC gains without counting in the process node (power/clock). Clock and IPC would give the final performance of course.
Reactions: Vattila
uzzi38
524
469
While I agree, the question was about performance, not IPC ;)
Ajay
6,357
1,941
OT:
That's because AMD GPUs have such a terrible perf/watt compared to NV. Clearly, they have a big delta to cover just as with the construction core compared to Zen. Also, all we know is that RDNA2 is being manufacturing on '7nm', not which precise node.
Ajay
6,357
1,941
What's crazy is as recently as 2016 it was thought that transistors smaller than 7nm would be highly susceptible to quantum tunneling. That didn't turn out to be an issue as processes move from N7 to N7P/N7+ to 6/5 for TSMC, and even Samsung targeting 3nm GAAFET production in 2021.
The main future issue is that 1 silicon atom is 0.2nm wide. It seems the industry has said they are unsure if nodes beyond 3nm would be viable, though TSMC is researching 2nm, and Intel thinks they can do 1.4nm by 2029.
Circling back to Zen4... if on 5nm, and if it doesn't drop til 2022, it may be very interesting market-wise. If Intel can get 7nm out by then (I know, but bear with me), they *might* regain the process lead. I think this path is the only way I could see them doing so in the next 5 years. 5nm TSMC is projected to have 171.3 MTr/mm2 and 7nm Intel is projected to have 237.18 MTr/mm2.
In any case, it's remarkable to see that we are going to see roughly a doubling of # of transistors from 7nm to 5nm so quickly and if TSMC keeps up the cadence, it'll happen still at a speed nearly in accordance with Moore's observation, even though we are starting to approach a literal atomic limit.
Forgot to get back to this. I meant the 'marketing' 1nm. Quantum effects were already an issue with Intel's 22nm FinFETs, forget about dealing with actual feature sizes in the 1nm range; I just don’t see that happening in the next 20 years.
uzzi38
524
469
OT:
1. Low hanging fruit is nice and all, but the same was claimed for RDNA3.
2. RDNA1 is on N7P. It doesn't matter which flavour of N7 RDNA2 is on, because best case is N7+ and N7+ is only 3% better in efficiency than N7P.
It's almost all uArch boyo.
Reactions: lobz
Ajay
6,357
1,941
I don't know what you are talking about. Don't call me boyo, K?
DisEnchantment
356
451
It seems to me that the X3D packaging that AMD is talking about could be TSMC's CoWoS with SoIC.
2.5D HBM and 3D SoC?
Also AMD registered some new patent applications for chiplet IVR.
20200066677
A data processor is implemented as an integrated circuit. The data processor includes a processor die. The processor die is connected to an integrated voltage regulator die using die-to-die bonding. The integrated voltage regulator die provides a regulated voltage to the processor die, and the processor die operates in response to the regulated voltage.
amrnuke
531
519
20200066677
This is really cool, honestly. I'm sure there's a math equation that tells us how beneficial this could be, but by adding 3D packaging, you can nearly double the number of points a given distance away. That could be really huge.
Hans Gruber
817
193
There is speculation that Nvidia is going to wait for Big Navi to release so they see what they are up against. Instead of releasing the next generation Nvidia GPU's.
ASK THE COMMUNITY
