- Jun 24, 2008
- 5,382
- 65
- 91
I want to do the same thing this guy has done
https://www.youtube.com/watch?v=KwROlDMjcwc
but mine are going to be way taller (160 cm) so I need the base to be quite heavy (I'm kinda set on 40 cm x 40 cm size), and I also don't want to paint them black (propose alternative colors that would look decent with white walls and wooden floor and furniture if you have any though) but want the wood to show (if there's no good alternative to black).
So what can I do?
I think I'm gonna have to go with MDF, it's the only material sold thick enough to make a heavy enough base it appears, and it's also high density unlike any other cheap options. It's cheap. But I hate how it looks naked.
Solid wood costs a lot more here than in the US and I haven't seen any 5 cm thick like the guide on tnt-audio uses (two 12 x 12 inches pieces of oak that thick, for 15$???? Not real).
I haven't seen anything like iron-on veneer in the shop and I'd prefer to keep it simple.
The shop sells veneered particle board but I think that's way too light and it's not sold thick.
I thought maybe I could use MDF for the base and leave the wood grain on view on the column, trouble is, how do I make the wood agree with a solid (matte or polish) finish? Are idea about colors/textures?
Thanks for your help.
So what can I do?
