DualMonitors
Hi All: i just purchased a Panasonic TC-L32x1 which will soon be connected via HDMI to a Samsung SMT-H3050 High Definition box from Time Warner NYC. (this is my bedroom TV set)
As the sound of the 32x1 is very mediocre, I thought that i'd get speakers for it. the 32x1 ONLY has an optical audio out (there's no analog audio outputs).
So the thought crossed my mind about getting a pair of external powered speakers/monitors that not only has built-in amps, but also an optical input and, by definition, also has to have a digital to analog converter, so i can simply connect the Panasonic 32x1 to the "digital optical input monitors" and let the external speakers/monitors decode the optical audio output, amplify the signals, and play it back via the speakers/monitors.
I looked at various web sellers and found these Behringer MS40 Digital Monitors. Links: http://www.zzounds.com/item--BEHMS40
Owners' Manual and Spec sheet is under the "Docs" tab on that page via the link above.
I'm uncertain that these are the only possibilities or these are the "best" and most suitable possibilities.
I also thought that if i can input into these hypothetical monitor speakers a tuner input, that can provide background music for my dog when i'm out. Currently, he has a Yamaha receiver (low end) and CD carousel from a number of years ago - too bulky (both boxes are not small) and the Yamaha receiver lacks optical audio outputs. However, the front headphones jack (1/4" jack) can be used to output into 2 RCA's for right and left audio outputs and plugged into the Behringer MS40 monitors mentioned above.
This is not a well thought out scenario but I thought that it is a start. May i kindly ask for further thoughts, suggestions, alternatives, advice?
Thanks in advance!
Thanks in advance!
