<< In the most basic sence, say you have 2 sounds. one at 60 hertz another at 1000. ( 60 hertz is base ) at 60 hertz, the speaker cone is moving in and out 60 times a second. Just because it is moving in and out at 60 does nto mean that on the way down it can not reverse a 1000th of an inch and hit that 1000 hertz note.
The problem is when you have a big cone ( 15' woofer ) the mass of the cone does not want to reverse, and you can warp the cone. Then you get noise induced. That is why you use a crossover, so only the lows go to the subs. >>
Actually the cone does not have to "reverse" its direction, a deceleration in its movement is sufficient. Sine wave (or a single frequency) is the simplest wave form. When two sine waves of different frequencies are added (superimposed), the result is a slighly deformed wave. When a speaker coil is fed with this, the cone moves exactly as the amplitude (of this resultant wave). Thus, we get a faithful reproduction of sound.
In the case of a big cone, the inertia of the cone, because of its bigger mass, restricts itself from accelerating/decelerating quicker. Thus cones with bigger mass fails to reprodice high frequency sound.
