Originally posted by: DVad3r
Everything is connected. The speakers just started to die at random taking longer and longer to boot up after I would turn them on from the pod. Its been over an hour now and still no sound. Could it be that the amp inside the sub has died?
Just making sure...you have the promedia 5.1 ultras, and not the GMX series or whatever, right? It said ultra in your title, but the GMX is the one with the "pod" looking controller...
I know the GMX's have had all sorts of trouble. I use the promedia 5.1 ultras and theyve worked perfectly (bought them they day the ultras came out, used em hard ever since).
Yeah, id do whats suggested, make sure all the plugs are working (plug some headphones in) on the soundcard, and if all those work then check the speakers. Maybe if you have another computer, plug em into there?
