thestrangebrew1
I've got an older projector that I'll be using for outdoor movie watching on a screen in the backyard. It's going to be hooked up to a laptop via a DVI-HDMI cable. For sound, I'm looking for some decent speakers that I could plug into the laptop and get sound out of. The laptop has a 3.5mm jack in the front so I was wondering if: a) Is there a speaker set that exists that plugs into a 3.5mm jack in the laptop that I can use b) recommend me a decent set.
I'm thinking a 2.1 set would be fine. It'll be outdoors so it's not like I can crank them up anyways. But I'm also looking for a set that's sub $100 (it is for outdoor use primarily so I don't need top notch). TIA
