speakers and sound card
dud2k
hey
i just recently purchased a new set of logitech Z560's (Mmmm...hope they come soon), and the sound card i use right now is a sonic impact s100. would the sonic impact s100 support a 4.1 speaker setup?
if they do..how would the sound compare with a turtle beach soundcard?
thx
check the back of the sound card. if it has an output jack for front and rear speakers, then you can plug both outputs into the control center. if it only has one output, you can use the M3D option to let the speakers create the rear sound field for you.
