Speaker T/S tester: technical help(electonics)
Lithium381
12,452
http://www.webervst.com/spkrcalc/para.htm
I'm using that as a guideline to get some specs on a speaker i got for really cheap at a garage sale, and i don't have any information on it.
for the resistors, i have (2) 1k ohm 1w resistors, and (2) 10 ohm .5w resistors......is that the right type? if not what do i need? please help so i can finally put these cones to good use
Viperoni
11,084
yup, the 1k (1000) ohm is correct, but you REALLY want to get the correct 10ohm resistor.
The 1% tolerance is very important......
PM me dood :)
