- Jul 14, 2003
- 1,142
- 13
- 81
I just have a quick question. I recently built a new rig and I used the Gigabyte GA-965P-DS3 motherboard.
My question is fairly simple. I may have plugged in some the front panel jumpers upside down. It's hard for me to tell which way they go. I usually have to flip them a couple of times to get them right when I am assembling a rig.
Anyways, when I power on the computer there is one long (and much louder) beep, followed by the familiar short beep that I usually hear. I checked the manual and it says one long and one short would indicate a DRAM or Motherboard problem.
Would having the front panel jumpers connected incorrectly prompt the system to do this? Or do I have a bigger problem on my hands that I need to identify?
Thanks for any help you can offer me.
