Speaker and Sub installation Yamaha Receiver
purbeast0
53,637
6,518
should be good to go. the only other thing you may want but it's not necessary are banana plugs. they just make plugging the speaker wires in/out easier and look cleaner.
but again, they are 100% unnecessary and you will be fine without them.
fralexandr
2,288
228
www.flickr.com
BeeBoop
1,677
fyi the wires you ordered are CCA (copper clad aluminum)
you might want to buy pure copper, but the main difference will be in the distance you can safely run it.
http://www.youtube.com/watch?v=vJt6C2tvPBQ
the person's probably running a ton of power through those wires to cause that heat up though :p.
http://www.monoprice.com/Search/Index?keyword=speaker+wire
Do you have a link or know where i can get some pure copper wires?
Edit:
Ahh okay thanks. I was hopping for Amazon though. I love amazon.
Edit2
I found this on Amazon. Is it any good?
Oyeve
22,066
883
Your original CCA wire you picked is more than good enough. Unless you are running longer than 80' there will be no difference.
