SPDIF To Optical???
MiniThug
1,057
Does such a thing exist? Im wanting to hook my computer up to my reciever but only have one digital coax input (already used by my dvd player) and 3 optical inputs which are going unused. I have found a long enough optical cable but my sound card, the Soundblaster Live only has a SPDIF out, no optical output. Are there converters available and if so, where might I find one?
Thanks
Mday
18,647
MiniThug
1,057
Basically I want to run an optical cable from my reciever to my computer. I have no optical output on my computer so I need something to convert the SPDIF - out so I can hook up my optical cable and run it to the reciever.
madthumbs
Banned
Oct 1, 2000
2,680
The optical cable is SPDIF (Sony / Philips Digital InterFace). spdif can be optical or coax. You're likely to lose sound quality switching to optical unless you invest in really good cables, though the problem is likely that you don't have the coax input on your amp?
Mday
18,647
you mean you want to convert the digital coaxial input on your sound card to toslink which your receiver uses. the above (what i linked) will do that.
spdif is a protocol. the optical cable commonly used is toslink. his problem is that he only has one digital coax jack in his receiver.
MiniThug
1,057
So will the loss be significant? I could switch the DVD player to optical and run my coax to the computer if needed. However I want the best sound possible through my DVD player, the computer is second in priority/.
Oct 16, 2002
142
I'm not sure if you'd be interested, but I have a Midiman CO2 Coaxial/optical converter - 2 coax jacks and 2 optical jacks - it does optical->coax and coax->optical and bi-directional as well. I bought it and never used it. It's a very high quality part - I never thought about selling it but I guess I would since I never use it. $50. I think it lists for $80.
midiman co2
John
Moderator Emeritus<br>Elite Member
I doubt you'll be able to hear the difference on your equipment between the 75ohm coax and a toslink cable.
snailophone
65
midiman co2
I have to second this suggestion. This is a great unit (as is everything from M-Audio)
MiniThug
1,057
How would a product such as this work for me?
M-Audio Sonica
I could just sell off my current sound card, and use this for the optical out. Would the sound quality of this be superior to the Creative? It says it outputs PCM, AC3 and DTS over the optical out, what can the Creative Soundblaster Live output?
mosco
940
Originally posted by: snailophone
Originally posted by: Howard
The M-Audio Revolution 7.1 is a nice sound card.
Yes, probably the best sound card ever for 100 bucks!
But the revolution doesn't have optical out, which kinda defeats the purpose for what he needs.
