I recently Bought a FoxconnNF4K8AC-RS , although setting it up and installing has gone through without a glitch i only have one niggle.
Thats with the coaxial sound port. I need to use the coaxial sound port for my sound as i use a Yamaha RX-V350 Home Cinema reciever , but when i connect the coaxial cable in , the reciever only displays two speakers and then goes into Dolby PCM mode . Yet in my old Asus a78nxe-deluxe socket a motherboard when i used this port the s all the 5 speakers would display on the reciever and it would then change to Dolby digital , even if it was in windows.
The other problem i have is , i only seem to get sound when i install the main Real AC97 audio driver set from the foxconnn cd.. but still then only stereo sound in whatever program i run . If i install the nvidia soundstorm drivers i get no sound at all 🙁
this is really confusing for me as this is the only motherboard ive had problems like this with the coaxial.. others have just reconised 5.1 straight away on the receiver.
Is this a driver problem you think?Would it be worth upgrading to a SB Audigy 2 Platium set as its really cheap at ebuyer atm if im only going to be using it for the digital port?
As i really wana get the sound setup properly again as it sound utterly pants atm 🙁
Reciever icons when connected to the new motherboard :
http://img442.imageshack.us/img442/9581/speakers15vm.jpg
Reciever Icons when connected to the old motherboard :
http://img442.imageshack.us/img442/7016/speakers24ye.jpg
Sound Control Panel About Screen
http://img377.imageshack.us/my.php?image=sound31wk.jpg
SPDIF Settings
http://img377.imageshack.us/my.php?image=sound38qf.jpg
thanks for anyhelp 😀
been puzzling me for weeks 🙁
SPDIF Settings
