SPDIF .. optical audio
112
101
What exactly is the SPDIF used for? It came with my mobo, but I don't see any use for it? What equipment uses the spdif plugs? Thanks.
shr
47
Digital in from a decent CD/MD player otherwise your go Digital/Analog/Digital conversion thru cheap DAs
Woodchuck2000
1,632
SPDIF Input - Used for digital input from a digital source such as a CD player, DVD player, Minidisc etc.
SPDIF Ouput - Used to output to a digital recorder/amplifer. I use mine to hook up to my receiver and also to record from CDs to my portable Minidisc player.
madthumbs
Banned
Oct 1, 2000
2,680
I use a Turtle Beach Santa Cruz. The spdif output to my dolby digital reciever sounds much better than internally decoded ac3 audio. If you watch movies using your computer you can get better sound by running it to your dolby digital reciever as long as you select spdif out in your media player. Some players such as Sasami2k do not support spdif out.
Jan 9, 2002
5,232
If I'm correct, you can hook it up to a receiver's optical input and get Dolby Digital 5.1 surround or better depending on the chipset and the source audio type.
chizow
9,537
You guys are using mini-plug to toslink/optical cables right? Pisses me off, my $30 monster cable is going to collect dust now :( and now I'll have to shell out some more bux on a piece of cable :(
Chiz
LikeLinus
11,518
670
Can you get 1/8" jack to Optical?? I'm getting my TB SC this week (was using a SB Live) and i assumed i'd just use an 1/8 to RCA and use my digitcal coaxial on my Denon 3802 receiver. How have others been doing it
chizow
9,537
Here's what I'll be
hunting for at BB. I'm not sure a mini ---> RCA to coax in will keep the digital signal intact, but I have no idea.
Chiz
Pariah
7,357
20
mini to RCA is a pretty standard used cable for coax, there is no conversion to coax. Mini to TOS is a rarely used conversion and should only be used if no other options exist.
chizow
9,537
So if I get a mini to RCA for my spdif out and plug it into the coax in on my receiver the digital signal will be intact (ie. I will get 5.1 DTS on my receiver?). This would be a pretty big difference IMO as I know monster charges an arm and a leg for anything with the toslink optical header.
TIA,
Chiz
Pariah
7,357
20
yea, you can use pretty much any $5 cable from radio shack that fits the mini to RCA characteristics and it will work fine.
LikeLinus
11,518
670
I've been using the Digital Coaxial input of my denon from my SBLive. It sounds great so far. I've got most of the parts for an HTPC on its way...so that's why i wanted to be sure i was doing it right. That's why i got a TB SC cause It's supposed to have better music SQ. We shall see!
RaynorWolfcastle
8,968
16
I use the optical SPDIF out on my Aureal Vortex2 to transfer music to my MD-Recorder :). I also use optical to connect my DVD Player to my receiver, though I could've used digital coaxial as well :)
