I'm using my PC as a source for an external DAC and amp (Keces DA-131.1 to a Shanling PH-100). I've had this setup working for about two months, but recently after re-arranging my office I'm getting a nasty buzz when moving the mouse (USB). I was originally using the SPDIF output on my X-Fi with no problems. In an attempt to isolate the problem I tried the coax output on my P5Q Deluxe with the same results. I've managed to eliminate it by using the TOSLINK output on the P5Q, but ideally I would like to use the X-Fi for everything so I need to fix this.
What should I be looking at as a culprit? I've never had to deal with this kind of issue on a digital connection, but it's definitely related to the physical connection between DAC & source. It buzzes when connected even if digital output is disabled.
Viper GTS
Viper GTS
