Originally posted by: Zenmervolt
In terms of fittiment, the plugs are identical (i.e. the BPR6ES will fit properly in any engine that uses the BPR5ES and vice versa).
BPRxES is an NGK part number (which makes sense, Honda contracts out their "factory" plugs to NGK). The BPR5ES will run hotter than the BPR6ES. Running a BPR6ES in an engine designed for a BPR5ES may cause premature fouling, and running a BPR5ES in an engine designed for a BPR6ES may cause detonation. For more information about decoding NGK plugs, you can follow the link at the end of this post.
In practice, a lawn mower engine is not a hugely sensitive piece of machinery and there are large tolerances built into the design. Either plug should work acceptably.
Decoding NGK plug numbers:
http://www.kaila.net/tl125/tl125ngkcode.html
ZV
