I am thinking of getting this PSU since my last 520W PSU just died after a few years of use. I have an Abit NF7-S, Radeon 9200, four hard drives, four optical drives, Audigy 2 Platinum, 5 case fans, about 6 USB devices, 512mb Corsair, Athlon XP 2500@3200, and all of the normal stuff like floppy drives and such.
--Question 1:
I understand that the connector is the 24+8-pin cable and that it may come with a 20+4-pin cable. Is that one single 24-pin connector or a 20-pin connector with a separate four-pin connector? If it is 24, I will have to find a 24 to 20-pin adapter, as the 24-pin cable will not fit in the NF7-S.
--Question 2:
How loud is this unit? My fans are pretty quiet and I do not want to add any significant noise.
--Question 3:
I have found the FSP550-60PLG on Newegg and the FSP550-60PLN on Directron. What is the difference between these two units?
http://www.fsp-group.com.tw/en...&factorname=EPS12V
--Question 4:
Does it matter that it does not have separate 12v rails?
--Question 5:
Any other recommendations for PSU?s besides this one?
Thanks for the help!
--Question 1:
--Question 2:
--Question 3:
--Question 4:
--Question 5:
