- Sep 4, 2006
- 16,800
- 45
- 91
So, there are replaceable seals that seal off the oil within the valve cover from the spark plug tube that contains the spark plug. Sounds nice. Of course, I forgot after I took all my spark plug valve cover seals off which way to install these seals. (They go on one of two ways)
I installed them, probably, the correct way the first time. However, I noticed when I took off my valve cover (I was replacing a valve cover bolt that broke) that my seals were all pretty much ruined. They all got sliced to shit by the spark plug tubes. (Sharp fuckers, apparently) And I thought, "Well, I probably installed them the wrong direction..." So I bought a new valve cover gasket set ($15. Both sets I've used so far are Felpro). Installed them the other way. Aligned the holes as best as I could with the valve cover... No go, Joe. It sliced the shit out of those ones too.
What the fuck do I do? How do I avoid this? It seems UNAVOIDABLE. Does the inner ring of these seals go INSIDE the spark plug tube or outside? (Either way could make sense!)
It's ridiculous. I've gone through two sets. So far I haven't had a misfire (as far as I can tell) with either set. (A symptom I would imagine from having too much oil in your spark plug tube)
The first set didn't have any noticeable amount of oil in the spark plug tube. I'll go check the spark plug tubes later. (I just drove 250+ miles on this new set)
Whatever! I need a good video! It doesn't seem possible to NOT cut the rubber on these. (Made Felpro just fucked up with their measurements)
